Correct Oil 2.0 D4D
paigerich
Hi
I've got a Corolla 2.0 D4D which is due an oil change. I've just bought some Castrol Magnatec 5W 30 (fully synthetic) A1.
Is this any good for my car? If not what is?
Many thanks
Paigerich
See pinned topic 'Engine Oil' at top of Corolla Club home page
Hi frostyballs,
Yeah, I read that before I posted. Sadly all that tells me is that I need 5W 30 for the 2.0 D4D. For me a amateur mechanic there's all the other stuff that goes with. A1/B1 etc etc.
I know it's a bit vague but all I wanted was a yes or know.
Thank you
Rich
"These grades above are listed by Toyota as they meet the following required specifications:
API grade SL or SM multigrade engine oil
API grade SL “Energy-Conserving”. SM “Energy-Conserving” or ILSAC* multigrade engine oil.
Toyota can only require the oils used meet the minimum specifications above. So long a the oil used meets the above the oil grade is not enforceable."
According to the Halfords site that your link is to, Castrol Magnatec 5W-30 A1 has the following spec
  • API SL CF
  • ILSAC GF-3
  • ACEA A1 B1
So Yes
Ok thank you
I'd be very careful about using Castrol Magnatec 5W-30 A1! Lots of problems... Go for Mobil 1 ESP or Motul or Shell Helix Ultra Extra...
Hi mistermena
Thanks for that but why? Isn't it a good oil? According to the bottle, it is Toyota approved, so I don't understand but I'm more than willing to listen other peoples opinions especially if they have experience of it.
Thanks again
I think if you look at some posts that member "CharlieFarlie" made I think that will explain some issues!... As far as I remember after using that oil in his RAV T-180 the engine died!...
  • 1 year later...
Hi there,
I drive with Castrol Edge 5w30 ( I am not sure about the A grade though, will check on the bottle). I have done more than 3000km and I can say the engine works great.
No problems whatsoever.
I hardly reckon this is the only ( if it is at all) reason for the engine to die!
