Diff Oil Change
Gav rav
Please can someone point me in the right direction for instructions how to do this?
Cheers,
Gav
Doesn't seem to be a ready made guide on here. But the short and sweet version afaik;
Obtain 0.51L of API GL-5 SAE 90 oil
FIRST- Make sure you can undo the fill plug!
Undo drain plug and let it all out (phew, stinks!)
Refit drain plug to 39 Nm (with new washer? Someone clarify please?!) with a smear of oil on.
Fill her up with difficulty (I have a garden sprayer/pump for this task, other methods available)
Refit fill plug
Bob's year Uncle
Dave
PS as a general rule, people called Dave make stuff up and don't actually know what they're talking about. But they mean well.
  • Like 3
Nae need to make all that up, Dave min..........see second last item in Pinned Section of 4.3 Maintenance Hints and Tips all done by Brownie 127 in the hills above Derby......
Remember, Gav min........before removal of any DRAIN plugs, check that the FILLER plug can be removed first to replenish, or else you will........weep openly.......
