Vibration at 2000rpm - again and again
ghsaunders40
A lot of people say it's a clutch issue.
Weirdly enough I get similar issues with my 1.0 CVT and it brings my urine to a boil when I drive it. I will be selling soon to buy an Auris Hybrid. Whether it's because the IQ has the 3 cyclinder engine, possible clutch, EGR.. Whatever the issue is, it's a pain in the balls having to chase it. Especially in your situation where it only has 3500 miles. Its either a really annoying defect or an extreme urine boiling characteristic of the car. Either way I think I've had enough.
Had the same issue; bad vibrations between 1800-2200 rpm. Replacing the clutch will fix the problem; something with unbalance in pressure group and uneven wear of plates.
Just had IT done, NO more vibrations, IQ is from februari 2009
In 2011 i bought my iQ 2 which is an Auto version and due to the various modifications i did to it shortly after purchasing it, i got to know the staff well at the dealership. About a year after my purchase the manager of the workshop stopped me to ask if i had bought the manual version. He said quite a few dealerships had reported a problem with the clutch juddering  and that if i had to look out for it and he would book it in for it to be replaced. Seems there area few on here reporting that very problem
David
Out of interest, how much did it cost you, and was it fixed at a Toyota dealership?
  Dave
General consensus is it's the clutch. A new one will sort it, but it will wear again and vibrate. Here's the thread I started which has had a lot of technical stuff dded over the last couple of weeks.
For me, it's not an issue. 300 miles from a £30 tank of town driving, no road tax, and a lovely looking little car far outweighs the vibration.
Thanks Jamski, that puts my mind to rest on the matter.  I too love the car and running costs.  Have just blanked out the noise (in my mind at least) as the clutch has only done 35000 so its got a while to go before it needs changing and that looks to be expensive with the labour costs.  Need to find an independent Toyota specialist as I doubt the run of the mill gearbox places will have experience of the IQ.Thanks again.
I'd also be interested to know, please, DnT1mmer. I've had a 2014 iQ for just a month and the resonance and shaking around 2000rpm under load (not present on the test drive, naturally…) are driving me nuts and spoiling a car that I otherwise like a great deal.
Just a wee note. Our car (1.0 manual 59 plate with 70,000+ miles) has the same problem, and usually I 'ease' that problem by backing off a bit on the pedal depression, and then bring it back up again. Depending on the gradient or road it can work a treat. Probably best on a 'level' road when having to change up as speed limit increases -as in accelerating from 30 to 40mph. Also, that 40mph limit sits around the 2000 rev mark... it is so annoying. However, I try not let it get me down, as it is easy to let negatives do that. As annoyed as I get, I try to remind myself of all the good things the iQ has brought to my motoring, as that vibration has to be the worst.
  Don't know if this is related to the vibration, but our exhaust came apart yesterday (Monday 16th Jan, and had only started blowing a bit on Saturday) at the front of the back box. I had to cut the rubbers holding the exhaust pipe and back box, as trying to wire it up so it didn't scrape on the road was not working. Car is in the dealers waiting for the part to arrive from Belgium. No idea yet how much the 'Ouch' part is going to be, just hope it's not too expensive as I have been saving my pennies to get the wheels refurbished and painted anthracite.
Just seen the cost of the exhaust !  Ouch.  Anyone know the cost of replacing the clutch on the 1L?
I bet the local tyre and exhaust place will be cheaper though?
I have been ignoring the shift light and kept the engine over 2200 rpm for years now.
It feels much more happy in general, like you're not constantly bogging it, and you actually have SOME torque available without downshifting.
Totally worth the 5%-10 increase in fuel consumption vs spending money on short term fixes.
Have to admit I am getting used to the vibration and just work around it.  The annoying thing is that I bought the IQ from a main dealer and although I heard the vibration on the test drive I put it down to the three cylinder engine and me not changing gear in time.  The rep must have known that the car had a vibration - i- could you have imagined on the test drive if the rep had said, don't worry about that annoying vibration - they all do that. It's no good taking it back as i find that the moment cash has changed hands the promises evaporate.  Apart from that the car is fun to drive as we initially  bought it to tow behind the motorhome - its now my main car as the fule consumption is great and it has a suprising amount of acceleration on the motorway - and we get two dogs in the back without any fuss.  The next job on the list is to change the front suspension drop links as I have the usual rattle noise when going over bumps.  I don't know if its common on the IQ but have bought two link bars to try and get rid of the noise  - funnily it only happens on the passenger side.
  • 1 year later...
I have the same problem and starting to think its a bad wheel bearing. Only getting the noise when car reaches 2000rpm in 4th gear or upper, or in 3rd gird going uphill reaching 2000rpm. Have an Auris diesel 1.4
If it's a wheel bearing, it won't be affected by engine revs. Wheel bearing vibration will be related to road speed (mph).
Also, if you press the clutch pedal while the vibration is present does it stop? If it's a wheel bearing the vibration will still be there.
Sorry I meant to write gearbox bearing - although I am curious to understand why only at 2000rpm and under pressure, don't know why ive put down wheel bearing (although that crossed my mind too)!
Yeah it stops but then again it looses the 2000rpm mark where it only occurs, so exactly 2000rpm, every other is fine, i can feel vibration in the gear changer and clutch when it happens, and the noise seems like coming from the top left side of the car, around the tyre.
Also lets say I hit 2000 rpm in downhill it will be a lot less noticable.
Mine has now done 50000 and is still making the same noise at 2000rpm. Have grown to live with it as local independent garage quoted £675 to replace the clutch.  They are gearbox specialists of over 30 years and had to admit they had never changed one and were surprised at the  book price for the replacement. I am going to assume that the engine needs to come out?  Its a pity that such a super car makes this fundamental noise.  Question is 'does it happen to all 1L manual cars or are some of us just unlucky?
Just had full exhaust fitted for £145 at Fiat dealers (yes a Fiat dealer).
Not unusual for what is probably the third party part. A few years ago we needed a rear box for a Honda, and the local Ford dealer was a lot cheaper than the Honda dealer.
  • 3 months later...
It cost us £450c to replace the clutch in our 98k mile 2010 iQ
Mod edit: reference to own company's website removed due to advertising
Labour time on these is something crazy like 6hours, whereas run of the mill aygos would have a labour time of about 3-4hours.
Hello everyone.
I'm the owner of an iq for a year now.
I also experience the vibration at 1800-2000rpm.
Had the clutch replacement fix the issue?
From Toyota UK today
"I would like to take this opportunity to explain that in our experience, typical vibration at 2000 rpm in 3 cylinder engine is not perceived to be an issue or fault and would be considered to be a characteristic."
  • 11 months later...
Hello all
i have recently purchased a 09 IQ, 45000 miles, 1.0 litre manual.
First of all i love the car, but i get a insane vibration underload in any gear between 1500-2000rpm has any one else had this problem?
also i would like to change the LEDs in the dash etc does anyone know how to do this or where to get it done?
Thank you in advance
Richard
Hi there,
I also have an 09 IQ 1.0 litre manual and I have this same vibration issue at 2000rpm. Unfortunately I cannot offer any advice, I am hoping to find out an answer too but glad to know its not just my car!
