Toyota Yaris Wet Carpet
anniew
I have a Toyota Yaris 1.3 colour collection 55 plate. The carpet on the passenger side is soaking wet. I do NOT have air con any ideas would be greatly received, is the heater matrix mounted on the passenger side, could this be the problem ?
Hello Anne - welcome to Toyota Owners Club.
Topic moved to the Yaris club.
Do you have a sunroof - have you checked the sunroof drainage channels aren't blocked?
Any vents in the scuttle (open the bonnet and look at the bulkhead in front of the windscreen) blocked with leaves or similar?
As above. If all OK lift the carpet, passenger side and look at the lower rear of the heater. You should see a rubber drain tube from the heater which should go out through the floor. If it is dislodged the water will drain into the car. If OK you need to remove the glovebox and check the pollen filter. If you need instructions on this just post.
Regards Geoff Peace.
