Got No Immobilizer Led Light No Starting
eme
toyota verso 2001.
Well the other night went out to car and noticed the inside lights
were dim, Battery was nearly flat. Now I had been out in car around 2 hours before.
Recharged Battery next day and car would not start. Called brake down out. As he
could not find anything wrong he tried to access the ecm. He could not connect to
it. Later after he left, I checked every fuse and relay. Inc fuses on side of
Battery. All ok. But the thing is the immobiliser LED is out even when the doors are
shut and ignition of. So I suspect power to or the imobilizer ecu itself. Can anyone
advise or has anyone had this. I have checked ecm but that only shows engine
ok. On computer. Other software I have only starts at 2004 so will not read
immobilizer faults codes. Thank you.
all sorted. it was a short on the case of the ecm. runing sweet again. just a bit of pulling things to bits but found it at last. i am a happy man.
Pleased that you managed to resolve the problem......Thanks for reporting back :)
