Uk Spec N 95 2L Gt St02 Non Starter
jimmy b
hello..ive ran a 2l gt uk spec 6th gen celica for 6 monthes...all fine..until I loaned it to a mate while he sorts out his sick golf..im in Essex & the car is in oxford..also ive not seen it /heard it.only via a mobile speakerphone.....but he said he opens the car..turns the key ..& all it does is crank over..ie turn turn turn...but no starting..so im off there tomorrow morning..now..im going to check the following..1.TAKE ALL PLUGS OUT 1 AT A TIME & CRANK THE CAR WITH THE PLUG ON THE HEAD..CHECK FOR SPARK..THEN MOVE ALONG X 4..NO SPARK?? CHECK FUSES,RELAYS COIL ETC..2. CHECK FUEL LINE UP TO THE FRONT OF THE CAR..NO FUEL...FUSE,,FUEL PUMP, RELAYS??..??3.BATTERY...NOT ENOUGH CRANKING.POWER../ JUMP START REPLACE Battery...4.I HAVE NO KEY FOB FOR THE CAR..I BOUGHT IT OFF E BAY..ONLY 1 X KEY..NEVER CAUSED CONCERN TILL NOW..ONLY HAD 1 X PROBLEM..IF LEFT 2/3 WEEKS THE Battery WAS FLAT..IE NO INTERIOR LIGHTS DASH LIGHTS NOTHING..CHUCK SOME JUMP LEADS ON ..& BANG..SHE FIRED UP..CENTRAL LOCKING,DOOR LIGHTS,WITH A STRANGE SUCKING NOISE COMING FROM NEAR THE AIR BOX AREA?? WTF??..APART FROM THAT..IM GETTING IT RECOVERED...BACK TO ESSEX ASAP..RE THE FACTORY FIT IMMOBILISER HOW DO I CHECK/REMOVE/BYPASS IT..??TA JIM..
