2002 Previa D4D 1Cd-Ftv - Vacuum Lines/ Hoses/ Problem
DanielBearman
Hi, I bought a 2002 previa D4D engine code 1CD-FTV. I've looked under the bonnet I've seen the vacuum lines look like madness. This engine is used in many cars so a lot if people here can help!
I need to know where all of the vacuums lines in the car are supposed to go to and where they come from. I really need help with this. OK so:
1. There is a screw in a vacuum line off the front passenger side of the engine - where is this supposed to go.?
2. A vacuum line seems to go in a circle. (The one with the green bit in the middle of the line). What about this one?
3. A few vacuum lines are missing. Any ideas where they go?
Diagrams are helpful. But if anyone knows where the sensors are supposed to be plugged into that would be good.
I hope you can help,
Dan.
  • 2 months later...
hi Daniel.
did you find any help?
I got the same problem because of a silly mechanic:(
hi Danial I can give you a detaild diagram - photos if that helps of the system I am quite familiar with the locations if it helps?
HI Luludog
I think this would be useful for a number of members. I too am interested in this diagram.
I would appreciate it if you could post pictures or diagrams on this thread.
Regards
Carl
