Auris 1.4D4D Problems With Hot Start
biker_boy07
Hello, from Bulgaria. I have auris 1.4 D4D 2007 year. I have problems with hot start, not with cold start. When it is cold it start realy easy for 1 second, but when it reaches working temperature the engine needs 3-4 seconds to start. Before 5-6 months i had a problem with the valve on the rail( i don't know the name in english), and i cleaned it, afther that i changed one of my injectors. Now injector's parameters are ok. I have techstream. The Battery is new. What it can be, scv ? Excuse me for my bad english.
Hello, the problem was Fuel Preassure Regulator. I changed it and now everything is fine.
Glad that you got your problem sorted, thanks for sharing the outcome too!
Good find, thanks for sharing :)
I was going to say it sounds like a similar problem 2.0 D4D Corollas have, but that is due to a design fault in the original starter motor
