Corolla Verso Electric Window Problem
Carlos_Wandingo
Hi All,
We have a '53 Plate Corolla Verso , and we have an issue with the passenger side window. It operates via the passenger side switch fine, but it doesn't work from the drivers side and the Window lock function is off ( the first thing i thought of :-) )
We have tried a replacement drivers side window switch assembly- just in case the locking switch was faulty , and we still get the same problem.
I am guessing its not fuse related at it operates from its own side fine. I have checked all the obvious fuses, etc , and they all look fine.
Any help would be appreciated :-)
Regards
Carl
