Indicators Not Flashing On Liteace
Lucas08
They were working, but occasionally did not flash. Now the lights just come on front and back without flashing.
Is this a simple fix?
Which relay do I need to change?
Thanks for your help
Lucas08
On my way to work yesterday they started working again!
Still don't know where to find the relay if they go again, but perhaps it is just the gremlins and now it will be fine.
Lucas08
I'd have thought it would be quite close to the fusebox. I don't think it'll be inside the fusebox though, more than likely mounted on some part of the bodywork close to it.
The flasher unit is usually is dependent on the current passing through a bi-metal strip bending then clicking back causing the on and off of the indicators.
If one bulb, lets say blows, then the current draw will be insufficient to enable to let this happen and just stay switched
'on'
Might be an idea to check the contact points in the bulb holders and the earthing are clean as any resistance to flow can have the same effect.
Del
