Vvt Actuator Problem
anotherone
Hi everyone, i'm a fresh member here so probably i'm bringing fresh problem :)
My iq is 2009y 1.0 with 120000km on odometer. I have lack of power problem, checked everything from spark plugs to removing catalytic converter... Finally I took it to dealer, after four hours of tests with no trouble codes diagnose was a vvt actuator...
Anyone had such kind of problem? Do those things brake? Or could it be clogged so oil pressure can't move it? And how bad is to change this thing? (I'm good with the mechanics, have done v8, v6 chain and belt driven engines) is it possible to do chain removing without taking engine out? Or is there a possibility of changing the actuator only by removing cam cover and accessing sprockets ( that would be to easy i guess). if anyone has done chain work I would appreciate any advice on what is the best way of doing it without taking out the engine...
Thanks in advance
Hey Viktoras, welcome here.. :-)
I read and think... hmmm... EGR?... another one?
Do a little search here... right upper on the page.. :-)
Greetz,
Peter
Egr is clean, works fine ( so I was told) I have checked the egr pipe and it was clean. As technician told me, the problem is that out of 27 times the actuator should move it moved only 2 times... I wonder how they could check it since it's a mechanical part, has no sensors...
Well perhaps ecu stores some kind of timing changes...
