Auris Problem Lights
giannis_33
Hello
I have an auris 2007 model and I was trying to update my bulbs with osram super bright bulbs..I did the mistake and I change the bulbs with lights on so suddenly drivers side stop working..small lights and the big lights are working perfectly but the normal that we use during night in the city is out..
I changed bulbs but nothing happened.
I checked the fuse box but wasn't saying anything in the diagram
Does anyone know what is going on?
I am pretty sure that power isn't coming to the bulb but is there any fuse for that?
Break out a tester and see if power is reaching the bulb, if not swap the fuse for a new one.
You didn't touch the glass of the bulb whilst fitting it as than can cause them to blow.
Thank you very much for your reply I have checked with tester and power is not going to the bulb..I quess it's a fuse but I cannot find it..I checked and the fuse box and under the hood but doesn't saying anything clearly..
It confusing me also that all the lights are working perfectly except this one and only in that side.. So is there for every light for every light a fuse?
It is on the driver's side.
Just a small plastic grey/white hatch which had all the fuses drawn on it.
The fuses are there.
The hatch isn't behind any panel, You can see it when when lying on the floor and look straight up.
I find that but the diagram is not detailed..
For me that I am not a pro I need to see left side low beam light or headlight to understand what it is..mostly it has some codes that I cannot understand
There are two fuse boxes, one is under the bonnet and the other is underneath the glove box.
When you remove the glove box you will see a circuit board in front of you.
The fuse box is underneath this circuit board and can be accessed by looking vertically from the floor
The headlight fuse is under the bonnet.
I saw the fuse Box it has and a paper that it is saying for which work is going the fuse
No headlight no low beam lights or something
The plastic and the bonnet it has also a diagram with some symbols but again it's not saying for low beam lights
