Engine Type
Paulstreasure
Hi
I have just purchased a 2008 Toyota Auris in France, it is a D4D 2 Liter model, I would like to check the tyre pressures before starting a 600 Km trip tomorrow, when I looked in the manual it says that there are 5 types of engines fitted to these cars, with different tyre pressures for each model.
Does anybody know how I tell which engine my model has ?
From the carte Grise (log book) it says that the number to identify the vehicle is SB1KD56E40f021741
There should be a plate on the front door ingo with the tyre pressures.
The engine in your Auris is the 1AD-FTV
Thanks very much Alan & Lee, I didn't fancy driving 1,200 Km on unknown tyre pressures.
Now to sort the next problem, after heavy rain in France last night, I have a boot full of water.
I presume this is the gaskets failing on the rear light clusters ?
I have driven corolla's for 30 years & they used to have this problem (normally just the right hand side), you would have thought Toyota would have resolved this issue by now !
it was right cluster for me, sealant sorted it, took 3 mins
  • 9 months later...
Well 8 months on from purchasing the Auris from a Toyota dealer in France.
What a disgrace this vehicle has been :-
Apart from the boot filling with water from the cheap pieces of foam glued behind the rear light clusters.
after 2 months the engine overheat warning light came on, took it to Toyota local dealer " no problem we will ring you to arrange appointment" 1 month later no call, went back to dealer who put it on diagnostics, " do not drive it again, the head gasket has gone, we will have to fit a new engine", new engine fitted.
1 month later air con ceased to operate "we will have to recharge the system " this had been recharged when I purchased 8 months before !
1 month on, Oil warning light comes on, Manual says Do not drive and call breakdown, Breakdown comes "checks oil,do not drive car, I will take it back to dealer you must have a major oil leak"
7 days later call Toyota, "what is wrong with my car ?" "Toyota says, sorry nobody has looked at your car for a week, a mechanic has been on holiday, call back at 17.00 " call back, "your car is ready tomorrow"
Collect car "what was wrong?" Toyota Mechanic says " this new engine drinks oil, you must check & top up oil once a week"
Despite telling Toyota on 3 occasions the brakes are still sqeeling at low speed
What a disgrace for Toyota, I have driven Corollas for 20 years and was aware of some of the failings, but why do they not sort out the problems ???? surely they must be aware ? years ago they sold a quality product & could justify & charge a premium because of this, but now, they are a disgrace, rant over.
And have you ever tried opening any of the windows above 50 mph ? the noise will burst you eardrums
