Car Starts Then Engine Stops
nobrains
My car starts then the then the engine stops unless i keep pressing the accelerator down
so, it runs fine if you apply a little accelerator?
Is the problem there when starting the engine from cold or already hot or both?
Things I would check would be Coolant Temperature Sensor, Throttle Position Sensor, and Idle Air Control Valve.
Could be simply a dirty connection on the plugs. Check all electrical connectors on the throttle body.
Do you have a workshop manual (e.g. Haynes) for reference to test these various components for correct operation?
got haynes manual, it runs if keep pressing accelarator down lift foot of a little and it stops
there are test procedures in the haynes manual for the aforementioned parts. A multimeter is required.
Does it do it when the engine is hot or cold or both?
When were the plugs, leads, distributor cap and rotor arm last changed?
