Changing Rear Light Cluster T27 Tourer
caveman_si
HI Folks, Anyone know how easy or hard it is to change the rear lights clusters on a t27 tourer?
Looks like i need might to change the drivers side rear cluster (body mounted not the ones in the boot), as the missus tells me some one has cracked it. Im guessing, unclip the electrics, undo 2/3 nuts, and just slide off? Any other clips that need to be undone? Just want to get some idea before i get back and look at it in a few days.
Cheers
I am surprised no one has commented yet. I do not have the T27 but I have changed the rear lights in t25 model, there was only 3 10mm nuts to take of each side and the electrical connector and the light just slid off, hopefully yours will be just as easy.
Just to follow up, The light cluster was easy to change. Unclip electrical connector, undo 3 nuts (10mm i think) and slide the cluster off.
Fitting is the reverse EXCEPT on the side of the car where the front of the cluster would be there is a knob/clip that the light cluster had to slide onto to positively locate it.
Thanks to Kingo for supplying the light cluster, it even came with indicator bulb already fitted so just unplug one and fit the other.
