Hello We Are The Pipercross And Ebc Shop
Pipercross and EBC Shop
Hello Toyota Owners Club
We are the Pipercross and EBC shop we are Retailers of the Full Pipercross and EBC range we deliver the
next working day in the UK if the item is in stock and across Europe.
We hold good levels of Pipercross stock both Panels and Induction kits and accessories at our main premises.
EBC has a 2pm cut off for next day orders as we are based 10 miles from EBC's Main warehouse.
An insight into some of the Pipercross Range:
Panel Filters
Special dry foam - designed to protect your air flow meter
Directly replaces the air filter in your airbox
30% more airflow over a standard paper air filter
Longer lifespan before cleaning required over cotton
Easy cleaning, no dirt caught like with V shaped filter grooves
Bench tested for improved fuel economy, power and torque outputs
Lifetime warranty on all replacement and performance road use filters
Intake Systems
Increase in both power and torque
Motorsport pedigree
Outperforms other air filters
Replaces the complete standard airbox
Includes full fitting kit and instructions for simple fitting
Increases engine note releasing the real noise of your engine
We can Supply the full EBC range of pads and discs which include:
Brake Pads:
Ultimax 2 Pads
Greenstuff Pads
Redstuff Pads
Yellowstuff Pads
Bluestuff Pads
Orangestuff Pads
Brake Shoes
And a wide range of Aftermarket Calipers Pads
Brake Discs/Rotors:
Premium Brake Discs
Turbogroove Discs
USR Discs
Blade Series Discs
Drums
As well as brake fluid, Brake Hoses, Wheel Cylinders, Brake Bleed Kits, Fluid Testers and Caliper Lube.
We will be offering discounts and group buys in the near future and will also keep you up to date on all new product releases as they happen.
Best Regards
Hello - welcome to Toyota Owners Club.
Hello
These are the Links to our dedicated Websites
Pipercross Shop: http://www.thepipercrossshop.co.uk/
EBC Brake Shop: http://www.ebcbrakeshop.co.uk/
We have now set up a new Voucher code that Offer's 10% all Pipercross items and for EBC 10% of orders over £100.
The Code is: 10OFF092015FORUM
To be able to use this code you have to register at that Website just trying to place an order just as a guest wont work.
For large EBC orders or if you some of you are planning of doing a group buy for Track pads please feel free to contact us we are always happy and willing to try and sort something out.
Regards
