2014 Hilux Fast Tickover On Start Up
henry plumb
I have a 2014 Toyota hilux 2.5 only done 6000 miles when start from cold ticks over fast for ages
then gos to normal then sometimes it does it when engine is warmed up you can watch rev counter
move have taken to dealer and they say nothing wrong but it doesent seem right to me its like its got a automatic choke has anybody else had this problem ?
Define 'fast'. My Verso usually ticks over at about 1k when it's cold. Once warmed up a little it settles somewhat lower. Tickover is also lumpy and hunts a little when it's doing a DPF regen.
ye that's about the same as my truck had an 08 plate one before and that dident do it
I think the quality of these trucks and cars has gone down hill slightly don't think I will
have it long
have it long
Its just the normal cold engine fast idle to aid quicker warm up especially when you`ve the heater control on HOT.
What else you gonna get...the Hilux by far still the best on the market
ye I no they the best this is me 4th one the best I think was a 52 plate
these newer ones are more comfortable to drive and have more power
but I don't remember the others having this fast tick over for so long after
starting and it sometimes does it when its warm
Probably to achieve better emissions, a cold engine pollutes more.
My 06 RAV4 ticks over around 1000rpm when the temp falls below 10 degrees. It will idle high until it warms up, then may go down slightly but can just go up on its own. Has done this for the last 4 years and is 100% normal in the summer.
