Gearbox Replacement From "semi-Automatic" To Manual On Yaris
terri7
hi
i got a yaris 1.4 diesel 2008 3 "doors" with a "semi-automatic" gearbox, the gearbox is not working well its hard to change between gears and i simply don't like it, so i was looking for manual gearboxes on the internet, and i want to replace it myself and couldn't find a good match with a good price, and i heard that there is other gearboxes from other Toyota models that could fit, which are they, and does anyone have any tips.
and i cant go to the a workshop and have them replace it, because it to expensive.
That would be a very big job and, unless you're a trained mechanic, I think it would be very difficult and laborious to do.
You'd need a new gearbox for starters, plus all the mounts, flywheel, clutch, new pedal assembly for the clutch pedal, hydraulics etc. and possibly even a different ECU?!
IMHO it'd be easier and possibly cheaper to part-ex the car for an equivalent manual one!
im actually aware of that but my question is witch gearbox can fit, can a corolla gearbox fit a yaris??
also dose anyone know if a gearbox that has been on a bensin fuell yaris can fit on diesel yaris?
Oh I see! Hmm, no idea then... suspect the gearbox from any 1.4 D4D (e.g. Corolla)
Saw this vid on youtube
so maybe there are generic gearboxes you could use??
