Parking Sensor Installation On My Yaris V 99 Reg
Smah
Hi Everyone.
I have got a aftermarket rear parking sensor which beeps and have LED option.I kinda know the procedure in general but not for my car.It will be very helpful if someone can guide me step by step according to my model of Yaris including information such as Where to feed the wire through,Taking the bumper off if required etc.I have attached the car picture although mine is 5 door hatchback and the aftermarket sensor that i have
Thank you in advance.
post-143674-0-59109900-1413469217_thumb.
post-143674-0-35346800-1413469223_thumb.
Moved to the Yaris club.
I also have an after market kit but decided not to go with the visual display which would need a lot more wirng and also somewhere to fix the actual display.
I just got the four sensors and beeper. Needs tyo be wired to the reversing lamp so that when reverse is engaged the sensors are activated. Should be able to tap into the wiring system in the rear area and keep everything hid in the boot well area and the beeper somewhere in the boot area.
Thanks Catlover,
Can you please make a video when you do it so i can do the same?It will be much appreciated.
Thanks again
Thanks Catlover,
Thanks again
Just dont hold your breathe, I have had my kit over 6 months now and not got round to fit it and still no desire. You may well decide to do yours before I do mine.
Joe
Thanks Catlover,
Thanks again
Joe
I have done all the drills and feeding the wires in.Can you please help me by guiding on where and which wire to connect.
You need to find the wires going to the reversing lamp. When you engae reverse the reversing lamps come on, thats when you wan the parking senors to activate as well.
You need to locate the lamp cluster with the reverse white light in it, then look for the wires going to that particlular white light bulb holder. Take a note of the colur(s) of the wire and see if you can locate it in a convinient place to join on the sensor wire.
Someone may well know where to get a wiring diagram which may show you the colours of the wires.
My Haynes shows Reversing light feed wire is coloured Red/White.
I used that - iirc- to wire my Meta reversing sensor - but that was years ago..
Thanks guys for all your support,Its all sorted now.It was a piece of cake.I was just worried for no reason.But i guess being precocious pays off :flowers:
Any photos of how you run the cables and the connections you made.?
