18" Tyre Pressures
Ben565
Hi, just wondering what pressures people are using with the 18" wheels on 2.2d4d (2012) book says 36 front and 34 rear, seems to ride better with them a couple of psi lower though.
You probably are not going to get many answers to this as Toyota UK registers very few Avensis 2.2 TSpirits/Excels per year (tens rather than hundreds) & probably most of those are demonstrators/management cars.
Have you checked the plate on the drivers B pillar?
My copy of the manual says for 91W tyres & under 99mph 37 front & 35 rear. For 95W tyres (what my Tourer runs) & under 99mph 40 front & 34 rear.
& how they feel will also vary according to the tyre construction i.e. softer/stiffer sidewall. I replaced the oem Bridgestones with Goodyears & they feel a bit softer.
Thanks, I didn't realise they sold so few. I have just switched from Bridgestone to Goodyear so maybe that's it more than the pressures. They are a 95W on the saloon too (although for the Eagle F1 they are a Y)
I must have misread the manual too, on the B pillar it's got 40psi front and 34psi rear. No wonder it felt soft.
