Landcruiser 2012 Gearbox Oil Filter
Gods_gift
Hi
My father inlaw has a 2012 Landcruiser with the 3 litre engine and we want to do an oil change on the gearbox. We've tried to source an oil filter for the gearbox but we are getting some bonkers prices from Toyota (£130+VAT!!).
Does anyone know how much the oil filter for the gearbox should be and are there any after market suppliers?
Thanks in advance.
Simon
The oil filter is not a cannister filter as would be fitted to the engine, it is fitted inside the gearbox sump and forms part of the oil pick up inside the gearbox. it is not regarded as a servicable part in the sense that Toyota do not give a scheduled mileage or age replacement point.
The replacement would require the removal of the sump, new drain and fill plug gaskets , sump gasket, oil filter pickup unit, 2lt of Toyota ATF WS and access to a compatible diagnostic computer capable of accessing the Transmission ECU to correctly fill and bleed the shift solenoids.
So the gearbox oil filter doesn't need replacing when you change the oil then as it isn't deemed a serviceable part?
There is no replacement schedule for the oil it is designed to last vehicle life
