Auris T180 Rear Brake Problem
murdoch
Hi
My rear drivers side calliper is leaking out the back where the handbrake connection is. I have a new seal kit, does anyone know where I can get a schematic of the calliper. Or, has anyone done this and can give me some advice?
I would normally have advised you to buy a new or rebuilt calliper Murdoch but since you already have the seal kit you might want to give it a go - on your head be it. I assume you have at least had previous experience of stripping and rebuilding brake systems - if not then I wouldn't recommend having a go at your rear calliper as your first attempt.
Anyway, here's some photos which might help you.
post-140480-0-13652200-1415554760_thumb.
post-140480-0-48730100-1415554776_thumb.
post-140480-0-01917100-1415554791_thumb.
thanks very much for this. I am a mechanic....or at least I was 32 years ago :flowers:. this diagram has helped greatly, fitted the kit and all working well.
KRGDS
John
