Central Locking Help
Daz Carr
Hi I'm new to this so please bear with me.
I have had an Auris for 6 years now and love it. The issue that I am now having is that when i lock the doors all but one locks. The rear passenges side door refuses to open or unlock when using the central locking. I am forced to leave the door locked untill i can get it to a garage.
I'm thinking that this will be quite expensive to fix but hope someone on here has had a simmilar problem and has a less expencive solution.
Any help is greatly appreciated.
Not sure about auris but my old hyundai had same problem. I took off the interior door panel and found that inside a mechanism was jammed, sprayed WD-40 on it and it started to work. Not sure if this may also help since all the other doors are working but check the fuse maybe?
Thanks for the tip. Just need to work out how to remove the door pannel.
