Toyota Liteace
ash121
hi, does anyone know if parts from any other toyota vans will fit a 1992 toyota liteace, like the townace/hiace, thanks
Some versions of the LiteAce and TownAce would be largely the same - and some components would be shared. As far as I'm aware the HiAce was a larger van, and any sharing of components would have been between the HiAce, the Granvia and the Regius.
thanks for the reply, there is a few townaces that almost have the same shape, its the steering column i need, can't seem to find one for the liteace
  • 5 years later...
I have just bought a Toyota Liteace  Noah, First made 2001 imported 2011 and converted to a Campervan
cant seem to find any part numbers for this vehicle and it is 47000km over a new cam belt 😱
could anybody help with some part numbers please?
Welcome Sue...put your frame number (JDM imports have frame numbers not VINs) into toyodiy..and you should get all the info you need.
https://www.toyodiy.com/parts/
or you could use "megazip" also
ps...the Voxy is basically the same vehicle.
Thanks a lot for the prompt reply Neil
I will have a go!
