Fuel Tank
Colm Jones
Hi, I'm trying to remove my fuel tank to clean it out. After draining it and flushing it I discovered biomass in the base of the tank. I had the tank almost off today but I cannot disconnect the electrical connector. Anyone here know if there is a knack to removing it?
post-145180-0-71117800-1417987516_thumb.
Not done it myself but it seems as you can tell the connectors gets rusted on and eventually falls apart as you do eventually pull them apart so will have to renew them
