Rear Door Not Locking With Central Locking
cmhnz
Hi all,
I've got a 2005 Avensis Estate and the right rear door lock refuses to lock or unlock when using either the remote central locking or the button on the drivers panel.
When I bought the car I didn't notice that it was temperamental, ie. it sometimes worked and sometimes didn't, however now it never seems to unlock or lock when using the central locking. Sometimes it attempts to unlock and fails - you can visually see the lock by the handle attempt to move, but fail.
I've taken the door panel off and everything looks clean and tidy - I suspect the panel has never been off before due to the condition of everything behind the panel, and no damage to the Avensis square that you have to pop off to remove the panel. Because the locking mechanism is inside the door, I'm not sure what I should be looking for or how to remove it to inspect it more closely.
Any assistance greatly appreciated.
Thanks,
Chris
