Instrument Cluster Swap - 98 Corolla 1.3 (E11) (4E-Fe)
mrhillmichael
Hello all!
I own a 1998 1.3 (E11) Corolla in red! 124k and counting!
However I would like to swap the instrument cluster over. It currently has one with no rev counter and a monster fuel and temp gauge. I would like to fit one with a rev gauge if possible.
http://www.ebay.co.uk/itm/1998-TOYOTA-COROLLA-1-3-3DR-HATCH-SPEEDOMETER-INSTRUMENT-CLUSTER-83800-1A060/191124490540?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140122125356%26meid%3Dc31499387db7475e9264e03a07fe5c82%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D281448431761&rt=nc
and this is the one I would like
http://www.ebay.co.uk/itm/TOYOTA-COROLLA-MK7-SPEEDOMETER-SPEEDO-INSTRUMENT-CLUSTER-57390-9390-1995-99-/281448431761?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACorolla+Compact%7CPlat_Gen%3A_E11_&hash=item4187a24091
My main concern is programming the mileage to be correct and actually getting the rev counter to work?
Any knowledge is greatly appreciated :euro::euro:
Thanks!
You won't be able to program the milege. I not sure if the dash will work, you may need to look at the connectors to see do they fit.
Normally these cars (dependant on chassis number) are pre-wired.
The rev counter may require a rpm pick up, a scan of live data using a code reader should be able to tell you as you will be able to see the engine rpm.
It could be worth trying one to see, but it would be a risk you would have to think about.
