Toyota Avensis Eobd 1 Codes 21, And 99
AV3
Hello
I have an illuminated EML. I have pulled the codes using the short pins 4 and 13 method.
This first code pulled is 21, which I believe is an O2 sensor.
The second flash code pulled was 99. I have not been able to find an EOBD 1 code list which has a value higher than 85.
We have owned this car since new and this is the first time the EML has activated.
Is anyone able to help identify why the second flash code with a value of 99 was able to be pulled from the diagnostic system?
The vehicle is a 2000 Avensis 1.8 Auto 7A-FE
Thanks for taking the time to read
99 is imbiblisor fault could have been stored trying 2 program a new key
Hello Ruairi
Thank you, I now have one less thing to worry about fixing.
Thanks again for taking time out from your day to answer my question.
Best regards
Evan
