Fault Code Help And Entertainment Ideas
bags
just jumped the E1 and TE1 pins on OBD and got a fault code 42 and 38. I know about the 42 but can't find what 38 is.
on another note, search youtube for
Matt Watson ultimate fishing hilux
Willie Apiata VC ultimate hunting hilux
Code 38 is directly related to the right rear speed sensor. Good Luck. Keep us informed.
Mike
Yota NZ said it is either the AT temp sensor fault or and ECU fault
  • 4 years later...
Hello everyone hope someone can help, I have a 1992 import surf, and today the check engine light came on. It dropped in power while the light was on and ran rough. The light came on and went off a couple of times, we have tried the E1 and TE1 trick but the light seemed to flashed over 30 odd times can someone point us in the right direction as to what is going on Thanks Kerie
It seems like I have 3 comments but I can't  find them and read
