K&n High Flow Performance Air Filter - 33-2486 Toyota Iq 1.00 / 1.
stujanes
***THIS FILTER IS AN UPGRADE FOR THE TOYOTA IQ EITHER THE 1.00 OR THE 1.33L ENGINE, THIS IS A BRAND NEW UN-OPENED OR USED***
K&N HIGH FLOW PERFORMANCE AIR FILTER - 33-2486
K&N's replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. They make over 1,200 different replacement air filters for virtually every vehicle on the road. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. With most vehicles you simply remove the disposable air filter and replace it with a K&N. See applicable instruction sheet for details. Their stock replacement air filters for street vehicles are covered by our famous K&N Million-Mile Limited Warranty? and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED.
Designed to boost horsepower and rate of acceleration
Can be cleaned and used again
High air flow with exceptional filtration
Lasts up to 50,000 miles before cleaning is required depending on driving conditions
Works with original equipment manufacturer vehicle electronics
Will NOT void vehicle warranty
Million Mile Limited Warranty©
Brand K&N
Type Performance Air Filter
Part Number 33-2486
Outer Length (mm) 332
Outer Width (mm) 137
Height (mm) 19
£47.00 Delivered as long as UK and not too far up in northern Scotland..
post-146297-0-62932400-1427289813_thumb.
This is now SOLD, thank you for your interest.
Please can a moderator close this thread.
Thanks.
SJ
