How To Check If Aygo Software Is Up To Date?
King Mustard
Model ID: 13TPDAEU-EA01
Hard No.: 86140-0H020
SAM ID: AEAICCJXOS
Audio: 0820
OS: 0621
myToyota and Toyota Customer Portal do not help.
I wouldn't know where else to start looking.
Not sure if the car is a 2014, 2015 or 2016 - it's an Aygo NG'14 x-pression x-wave 5dr x-shift with x-nav.
As we are only in April 2015, it certainly won't be a 2016 model!
That's what I was thinking but when I was registering for this forum earlier today, 2016 was an option :P
I would be interested to know if there is an update available too and for the SatNav app as well.
I posted a link on this forum for the dealer install manual of the satnav unit which contains a link within it on how to upload updated software on to the system.
Thanks for the info. Whereabouts on the forum?
Can you de me a big favour. Will you try an access the hidden menu as it shows you how to do it but I cannot get mine to work by flashing the main beam switch 3 times while holding down the menu button. Nothing happens.
Might be an error with the manual or slightly different system possibly.
To access the hidden menus you hold the menu button down and switch the headlamps on off 3 times by rotating the switch ( not pulling for full beam ) be careful it is possible to alter settings that may lock the system down and this is not covered under warranty!
The picture on the manual shows the main beam tell tale in Blue lit up so I just assumed that was what you did although it is unclear as the description tells you to operate the Dimmer switch.
