Blue Smoke And Lumpy Running For A Few Seconds On Startup
Lsco
Hi - I have a 2008 Toyota Auris Spirit Diesel, lately on start up I have been getting blue smoke on start up and it runs a bit lumpy for a few seconds, after that it runs perfectly all day, but will do it again if it stands till cold. I have been advised to change the glow plugs, and suggestions gratefully received
It could relate to a TSB (technical service bulletin) requiring an ecu reprogramme and/or a new SCV valve to cure cold start issue. I don't have the details to hand but a search on this forum should yield the results.
Blue smoke - oil.
Black smoke - excess fuel
White smoke - water (steam)
Well like Tom says blue smoke means oil issue what oil do you have in your car ... What engine size is it, how many miles ... What sort of driving do you do
Oil used is fully synthetic 5 -30, It has been using oil just recently. 08 vehicle 85,000 miles, I have been working close to home for the past 6 months, so it has been doing a lot of short trips, but I try to make sure it is at least at normal temperature before switching off.
I wonder if your seeping oil into the chamber from a gasket starting to go or turbo oil seal maybe ... How is the oil level ( how often are you topping it up and with how much are you topping it up with )
