Aftermarket Power Locks & Turn/hazard Lights
malinduta
Hello!
Just installed a aftermarket power locks on my 2009 aygo and is working great.
The unit has 2 wires that connect to turn lights and blink once for closed and two times for open.
The question is where should I connect those wires?
How to get to turn wires or to hazard wires? I tryed on hazard switch but is does not work.
Thank you!
connect into the wiring at the steering column as you have the wiring for your indicator stalk there.
if your not sure of the wiring code have a look at the wiring going to the indicator lamps front or rear.
look at the wiring colours going to the indicators you will see what colours are associated with the indicator
then look for that colour on the indicator stalk
it could be something like blue with a white tracer(stripe)
The wiring colours going to the indicators do not match on the indicator stalk. There is no white tracer on the indicator stalk.
Both left and right indicators have one white tracer. I guess is the ground. The other wire is different on right and left.
Also tryed something else: using a voltmeter, checked the connectivity from the indicator stalk to the indicators. The indicators have two wires, but the connectivity on the indicator stalk is on four pins.
Any thoughts?
check the wiring on the hazard light switch then you may find the wiring there
Here are some pictures with the inducator stalk and hazard lights wires.
post-148888-0-45192200-1436352608_thumb.post-148888-0-77040000-1436352608_thumb.post-148888-0-11989600-1436352609_thumb.
what colour wires do you have going to the indicators,we no longer have an aygo so i cannot go and have a look.
Front Left: Mauve (Pink) & White Trace
Front Right: Yellow & White Trace
Side Left: Yellowish & White Trace
Side Right: White & White Trace
post-148888-0-67386000-1436445686_thumb.post-148888-0-05142300-1436445687_thumb.post-148888-0-39718600-1436445687_thumb.post-148888-0-26621800-1436445686_thumb.
I don`t think I understand what it says there... :unsure:
the reason your wiring changes colour from the switch to the bulb is that everything goes through the combination meter (that is the circuit board on the speedo) so i feel your best option is to go to the back of the bulb.
the white / black is the earth connection so tap into the other coloured wire.
I aborted this project since is too complicated for me to get in the back of each buld.
Thank you for your support!
