Tpa800 Parking System Fuse For Auris
tp6821
Does anyone know where the fuse is located for the TPA800 parking aid system on a 1st generation (2007) Auris? Both the front and rear sensors start up always and immediately whenever I turn the engine on and it is starting to get really annoying! I've checked and there is no dirt around the sensors, they just seen to be a bit faulty and I would like to stop the beeping by disabling the system altogether. The green light desk to the dashboard only disables the system once the engine is running - I would like to stop the system from operating even before I turn the engine on!
Does anyone have any ideas which fuse I should be looking for?!
Many thanks
I don't think you can address this by removing the fuses. In my handbook it lists two fuses for the Park Assist #24 and 27 in the fuse panel behind the glovebox. But these fuses also control other circuits like back-up lights, airbag manual shut off etc so you wouldn't want to disable these.
I'd imagine you'll have to disable it through the setup programme and it might take a trip to the dealers to do that.
