Broken Oil Dip Stick Tube....
roddee47
Any idea how to fix broken oil dip stick tube?
Rod
Is there a piece still left in the engine then? How big a piece? Or if there is nothing left in engine just get a new one. Head to garage either...someone may have to drop the sump or they maybe able to get the piece out from the top.
@kenmavor; yup, there is a millimeter left from the broken tube . I am thinking of using copper tube to connect the broken tube, is it good idea? Or any idea?
Rod
You can get liquid metal that you mix from two packs and which sets like metal and is heat resistant. I've used it to repair a gaping hole through a sump before, among other things. It'll probably work if you get it clean. The stuff I used is Belzona E Metal.
@alan333; thanks ,try to shop in eBay ...
Rod
Rod
