Am2 Fuse
GillianG
I am new to this group and hope that you might be able to with my problem.
The Battery in my 1996 Camry keeps on going down, something is draining it and if I leave it for three days or more I need to put it on the charger. We have done a test with pulling out the fuses one at a time and found that the AM2 fuse seems to be the problem.
From my understanding this fuse is part of the ignition system and all the bits I have read talk about the fuse being blown not draining the Battery. My car has the 4sfe motor with 4 coils not a distributor so that may be the difference.
It is plainly causing a short but I am not sure how I fix it, so I am asking for help and hoping that someone here has some ideas that I can use.
GillianG
