Spark Plugs - 1.8, 2004
SaveOurSouls
I'm new to the forum and have owned a Toyota Avensis 2004 1.8 petrol for 7 years. In that time I have provided most of my own repair and servicing.
I have completely neglected the spark plugs and have started noticing issues relating to spark plugs needing a change, can anyone recommend which spark plugs would be suitable for my engine? I believe that Iridium tips are required?
Thanks,
Connor
Hello Connor - welcome to Toyota Owners Club
genuine ones are normally made by denso, alternatively I would NGK and Bosch
look at these
http://www.ebay.co.uk/itm/New-Genuine-Toyota-Avensis-Spark-Plugs-Set-4x90919-01164-K16R-U11-Original-Denso-/251936470248?hash=item3aa89574e8
Send them a email or phone with your reg and they will advise if they fit or will direct you to some that will.
or you could try www.eurocarparts.com
The correct plugs for your car are Denso K16R-U11
Cheers for the advice, I ended up checking what was in the car already before seeing the posts here and the plugs turned out to be NGK R BKR5EYA 11 so I bought four of the same as I hadn't had any issues with them previously.
I'll keep the Denso plugs in mind for future reference as I would prefer to keep the car using OEM parts.
