Motor Noise
Issamos
Hi guys
I recently can hear lound noise coming fron the engine when accelerating. This comes only when i accelerate hard.
Any suggestions?
It's like roaring when accelerating hard. Comming from the front of the engine.
Yes it is. But there is a small hole in the bottom of the air intake box. Is that normal?
If it's on the 'outside' of the filter it's probably just a drain for any water that gets pulled in or condenses in the box.
If it's on the 'engine' side I'd think not normal and starting looking for a loose hose end - probably to do with the emission control stuff.
You're right. It's on the outside, probably for drain. Not the cause.
There is a kind of squeaky noise close to the alternator. Could that cause the problem?
Sent from my SM-N7505 using Tapatalk
Sounds more likely to be the drive belt, possibly a bearing (alternator/water pump?). Probably not the cause of the roaring, but you should check it out anyway as it could be a first sign of something that will just get worse.
I did the water spray test and the noise disappear when i put water. My car is 43k miles do you think i need to change the drive belt?
Check the water pump and alternator...loosen the belt and remove, then spin each by hand, they should by silky smooth and silent.
I had to change my daughters yaris water pump that had this similar grumble.
  • 4 weeks later...
I removed the belt. The water pump and alternator are smooth but one of the pulleys moves a little bit. Could it be the reason?
