Wiechers Strut Bar Toyota Avensis T25
Regressor
Ok, so i actually bought a upper strut bar for my Toyota Avensis T25 2.0 D4D.
There is only 1 slight problem. The Vacuum Reservoir Sub-assy is in the way :p
Anyone fittet this to their car? I guess this is not a problem on the petrols.
Borrowing this from another thread:
Can you not temporarily remove it fit strut bar and re fit
Hi, i solved the issue. I had to remove the Vacuum Reservoir and drill a new hole in the bracket so i could lower the reservoir a little bit. It was not possible to fit the strut bar without some minor modifications.
If anyone decides to fit one too i could provide some pictures for a solution.
