Corolla Verso Front Wing Replacement
webkai
Unfortunately I pranged my Verso against a metal bollard. Despite the accident happening at close to zero speed, the passenger side front wing is so badly damaged that it needs to be replaced.
A couple of indie body shops have quoted over 500 quid to replace the panel, which seems like a lot for a car which isn't worth much more than that. So I'm thinking of having a go at DIY'ing it.
Does anyone have any experience of removing the front wing on a Verso?
Is it only bolts holding the wing in place, or are there also spot welds?
Should I use a seam-sealant when re-fitting the replacement panel?
Any advice on where to get a pre-painted panel to match the car?
Any other advice/tips much appreciated.
Thanks for any help.
Hi, I recomended to enter and registrer in www.toyotatech.eu
Here enterin in "Repair" in there "Accessory installation manual", introducind your car data, and in the deployed list you search "Parking Aid System" and then "TPA Front"
You have a PDF of disassemble the fornt bumper.
I hope this helps, and sorry for my English.
