toyota avensis t3-s d4d 53 estate
jem555
can anybody help i have no rear tail lights and my front side lights not working and no number plate lights my headlights are working fine and my green light on the dash not lighting up any idea thanks
Hi Jem,
First things first, have you checked the fuses? The locations are in the manual.
Ah ok, I don't know about the 53 paste but the fuses on mine are under the glove box passengers side. The fuse designations ate on the inside of the lid. There is another small one under the bonnet again passengers side. Inside the box you'll see a small tool which you use to pull the fuses out. Examine each one for the circuits in question in the light and see if there is a break.
Had the same problem on my t25 for about a year ago, and my solution was to change one of the relays that is located in the fusebox to the left under the steering wheel. Dont remember which one but I think there was 3 relays that you can check.
