What brand Fuel Injectors do I have?
Verso04
Would anyone know, or point me in the right direction as to finding out what brand fuel injectors my Toyota Corolla Verso, 2.0  D-4D might have.
2004 (Facelift Model)
Happy to supply any more info should that help.  Thanks
Toyota use Denso for their diesel injectors ( excl 1.4d4d which use Bosch
On 19/07/2016 at 7:58 PM, Devon Aygo said:
Toyota use Denso for their diesel injectors ( excl 1.4d4d which use Bosch )
Thank you Devon Aygo.
I was hoping I'd be able to send my injectors off to the various places via Royal Mail like you can with Petrol Injectors, get them ultrasonic cleaned & tested with a report for £12.50 each!
However I am hitting brick walls everywhere!  Apparently its not so straight forward with Diesel Injectors.
Is there anywhere I can get a similar sort of service with a similar price?
Please be careful - Diesel injectors run at waaay higher pressure than petrol ones!
I was hoping I'd be able to send my injectors off to the various places via Royal Mail like you can with Petrol Injectors, get them ultrasonic cleaned & tested with a report for £12.50 each! However I am hitting brick walls everywhere!  Apparently its not so straight forward with Diesel Injectors.
Try Ribble Diesel, get their phone by Google
Very true since petrol injectors have been indirect injection but I understand there's new high pressure direct injection systems for petrol engines now. I don't know much about it yet but Delphi has an item http://delphi.com/manufacturers/auto/powertrain/gas/injsys/p-gdi-h-p-fuel-pump saying they've got 400 bar delivery pumps. I don't suppose petrol injectors will ever need the very high pressure of diesels due to the difference in compression ratios.
It's a bit ironic that the diesel guys stole the idea of common-rail from the petrol guys innit?
