Rattling left hand side of air vent or glove compartment
Perfection
Anyone experienced a rattling of plastic noise around the front air vent region or glove compartment?
I get this noise when driving over bumps or rough surface.
This is a 2010 diesel 2.0 TR model.
Greetings..This noise could be coming from the air filter feed pipe. All plastic, and comes loose after x number of miles. Give the engine a blip, and you may hear it rattle. A known fault on lots of Toyota models around 2006 ish perhaps even still?..Easy to rectify. Just open the bonnet, right hand side of engine, filter box (black square thing) pipe from front of engine goes in there. grab it,  waggle it, yep it's loose! so glue it back with some silicone, or gaffer tape..job done..Mr Toyota will rush you 50 quid for that!..but wait..could it be the half empty tin of travel sweets..I don't think so...Good Luck...Tidzatornado
Thanks for the suggestion. I will look into that. My rattle only appears when going in over rough or bump.
