Touch & go 1 or touch & go 2
Mark Revill
Hi all,
After a small time away driving dear i say it a Tiguan i have now gone back to the good Rav4 and purchased a 2014 icon Rav4. What i am trying to do is establish if i have a touch 1 or touch 2 head unit. the number on the bottom right hand side of the head unit is 510014, and it does have Sat Nav.
I would like to upgrade it to the touch 2 plus with wifi but not sure if i can just purchase and fit the Sat nav unit to my head unit or if i have got to upgrade the whole system.
As per usual any help or advice would be greatly received.
PS. is there any thing i should check on the 2014 Rav4 at all its currently done 48000 miles
2014 is the change over point between T1 & T2 if you press "setup" "General" then " software version" what version does it show?
versions 1.#.# or 2.#.# are Touch 1
Versions 3.#.# or higher are Touch 2
If you have Touch 1 then upgrading to Touch 2 with Go pro is a big job as the dash harnesses , Headunit and Nav would all need changing and whilst the headunit and Nav are easy the dash harness would need the radio harness from a Touch 2 car cutting and splicing into the original harness.
Hi Devon Aygo,
Thank you very much for your informative reply.
I have checked as you say and hoping it is good news, The software version is: 4.2.2L  The map ID is: 2014 v1
I take it from this i have the touch 2.
Again many thanks for the information and the amazing site for Toyota.
11 hours ago, Mark Revill said:
Hi Devon Aygo,
Yes that software means you have Touch & Go 2 the "L" means it is standard nav and not the "H" high grade Go Pro, all you need to upgrade is the nav extension box for a Pro version to gain the extra features so long as you have the "Voice" function button on the steering wheel.
  • 5 years later...
Hi I have a Toyota Rac 4 2014 and checked my system it only shows software version as 000000 the unit is a 510014 and I would like to add a sat nav is this possible with this unit?
  • 1 year later...
Hi I have a touch plus in a 2013 rave4 model but would love a more up to date model that had ability for linking up CarPlay. I don’t really want to have mega wiring upgrades. Any ideas?
