aygo p0135
redcell
I have an error P0135 Sensor Heater Circuit (Bank: 1 Sensor:1), after some reading I decided to replace the front oxygen sensor, but this didn't fix the problem, I still get the P0135 error. so now I don't know what to do anymore. The aygo is from 2010, after the sensor is replaced does it need some milage for it to work, or should it work straight away?
I'll have a look in my error code book after dinner and see what it says and get back to you.
Out of interest did you clear the codes once the new sensor was fitted?
did you buy a toyota part or is it a 3rd party part you have.
i have found this on youtube
its not aygo specific but it will give you an idea of what else you can try
