Interior Lights
uniquestar
*****Ignore the below, I have just found the other lights behind the front seats, that, now set to door, turn on when the car opens.  Whoops!*****
Hi All,
I've just bought a 1.6 2006 Auris T-Spirit.  unfortunately the car did not come with the owner's manual.
When I unlock / turn off the car the interior lights don't illuminate as I would expect.  The lights work with the button, and I get a door open notification when I open the door, so it appears as all the sensors are working.
Is there an option or button somewhere to set this?
Many Thanks!
Edited by uniquestar
Found what I was looking for!
Yeap, you found it; central lamp only is working with door switches, front lamp didn't.  I managed to make front lamp to work with door switches as well, adding two 1 amp diodes - one for each bulb.
