Sloppy gear lever
bennmark0
Got an aygo noticed gear lever is getting sloppy,I've had a look at gear selector in car ,lever seems loose around top bush,anybody know if this bush can be replaced
Moved to the Aygo club
  • 10 months later...
Good Morning.
I know this is quite an old post, but this may be of interest:
https://www.ebay.co.uk/itm/Toyota-Aygo-Avensis-Cruiser-Hilux-gear-linkage-selector-bush-repair-kit/132410454698?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
These are the parts that fit around the ball. I think that to replace the ball a new gear lever is required. I suppose it depends on which parts are worn. I haven't tried replacing either yet. I think that to replace the lower part of the housing, the gear change mechanism needs to be unbolted from the floor to gain access to the bottom of it.
I would be interested to know how you get on.
Cheers,
Stefan
