Charging cable
Santii
Hi
just wondering if any thoughts on this cable? The car came with the one for home charging but also need one for regular charging points...16 or 32 amps?
many thanks
For the current plugin prius, a 16amp cable is fine.  It only takes 10amps max.
The new plugin (when it gets here) can use faster charging so a 32amp cable would be required in this case.
I got a cable for my pluigin from Amazon for just over £100.  ;)
Great deal! Could you send the link please? pratishks@gmail.com
Just search for EV Charging Cable Type 1 to Type 2 16 Amp
The one I got is currently out of stock.
I notice the one you have shown is 10m length. Mine is 5m length so it will be cheaper.
I use a 16amp for my PiP currently. A 32amp will also work, and be more future proofed, so worth potentially getting the 32amp for any PHEV you purchase at a later date.
You are going to have to do a lot of EV miles away from home using a charge point that needs a cable to justify the cost of that cable.
Right place right time and you can get a lead for around £65, saves £1-£1.20 per charge based on current petrol price, so only 60ish uses, and if used regularly that won't take long.
Full charge is equivalent to 1 litre of petrol for my plugin so a value of £1 to £1.20 per charge is about right.  If you can use it regularly the cable will pay for itself quickly.
If you plan on keeping the plugin for a few years, save money, get a cheap 16 amp cable.
It would take me a very long time as there are almost no local charge points and those that do exist are not where I want to go so I have only charged my car at home and even that was impossible for a while when the chargemaster unit failed. Santii would appear to have many more options living in London judging by the charging points shown on zapmap.
