BG244 diesel treatment - anyone?
NorthantsPete
So the low end torque issue is back.
I was using, as a test, regular diesel and its sufficient to say it makes a difference if I do (in a bad way!)
Im now on a full tank of BP ultimate as Shell was closed for the vpower
In the past ive run the full 15 quids worth (double dose) miller ecomax treatment aditive for about 300 litres or so and then it felt lively and churpy on shellvpower
Ive been told about BG244  one hit treatment - anyone used it?
Ideally id like to use this then continue with V-power to keep it clean
But Id like to know if anyones used it before spanking £25
Cheers
