Gearbox Problem
Gomoca
I wonder if some of you have ever had problems with the gearbox.
Today, with difficulty, I was able to drive the car to Toyota garage using the 1st and 3rd gear... My car is from 2009, 1.4 diesel, and has 158,000km's.
Any comments are welcome!
Thanks!
What was the problems you had? Can't select other gears? Popping out of gear? Crunching?
Sent from my Pixel using Tapatalk
Exactly! And the clutch had already been replaced at 120,000km.
I'm waiting for Toyota's 'feedback'. I saw on the net, there are problems in the gearbox in the 1st generation iq ...
I've seen bearings go on that box but not much else. Hopefully they find the cause.
Finally I had a response from Toyota related to the gearbox ... an anormal situation but, here's the warning.
In the velocity gear zone there is a metal spike, which was almost breaking.
The difficulty in putting the speed changes is justified.
